Sammelthread Asus Maximus II Formula (Intel P45)
Diskutiere und helfe bei Asus Maximus II Formula (Intel P45) im Bereich Mainboards im SysProfile Forum bei einer Lösung; [IMG] [IMG] Spezifikationen Bilder BIOS Wichtige Informationen Wichtige Links / Downloads [IMG] CPU: Intel Socket 775 Processors for Intel®... Discussion in 'Mainboards' started by devic, Aug 29, 2008.
  1. devic
    devic Computer-Versteher
    • Spezifikationen
    • Bilder
    • BIOS
    • Wichtige Informationen
    • Wichtige Links / Downloads
    CPU:
    • Intel Socket 775 Processors for Intel® Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® dual-core/Celeron® dual-core /Celeron® Processors
    • Support Intel® next generation 45nm Multi-Core CPU
    • Compatible with Intel® 06/05B/05A processors
    Chipsatz:
    • Intel P45 Chipsatz
    • Intel ICH10R Southbridge
    Speicher:
    • 4 x240-pin DIMM, Max. 16 GB, DDR2 1200/1066/800/667 Non-ECC,Un-buffered Memory
    • Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lidts).
    • When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
    QVL-Liste siehe Wichtige Links / Downloads
    Erweiterungs-Slots:
    • 2 x PCIe 2.0 x16 (single max @16,dual @ x8 speed)
    • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
    • 2 x PCI 2.2
    Multi-GPU Unterstützung:
    • Unterstützt ATI CrossFireX™
    Storage:
    • 6 xSATA 3 Gb/s ports Intel Matrix Storage Technology supports Support RAID 0,1,5,10 Marvell® 88SE6121 controller
    • 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
    • 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
    • Silicon Image Sil5723
    • 2 x SATA 3.0 Gb/s ports
    • Supports RAID 0, 1
    Audio:
    • SupremeFX X-Fi Audio Card
      - ADI® AD2000B 8-channel High Definition Audio CODEC
      - Creative X-Fi capability
      - X-Fi interface
    • Coaxial/Optical S/PDIF out ports
    LAN:
    • Dual Gigabit LAN, both featuring AI NET2
    • Support Teaming Technology
    Interne IO-Anschlüsse:
    • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
    • 1 x Floppy disk drive connector
    • 1 x IDE connector for two devices
    • 6 x SATA connectors (Blue)
    • 2 x Speeding HDD connectors (Black)
    • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
    • 3 x thermal sensor connectors
    • 1 x IEEE1394a connector
    • 1 x Chassis Intrusion connector
    • 24-pin ATX Power connector
    • 8-pin ATX 12V Power connector
    • 1 x En/Dis-able Clr CMOS
    • 1 x LCD Poster connector
    • 1 x ROG connector
    • 1 x Power-on switch
    • 1 x Reset switch
    • System panel connector
    externe IO-Anschlüsse:
    • 1 x PS/2 Keyboard port(purple)
    • 1 x eSATA port
    • 2 x LAN (RJ45) ports
    • 6 x USB 2.0/1.1 ports
    • 1 x IEEE1394a port
    • 1 x Clr CMOS switch
    Lieferumfang:
    • LCD Poster
    • ASUS Optional Fan
    • 3 in 1 ASUS Q-Connector Kit
    • UltraDMA 133/100/66 cable
    • Floppy disk drive cable
    • SATA cables
    • SATA power cables
    • 2-port USB2.0 + IEEE 1394a module
    • Q-Shield
    • Cable Ties
    • User's manual
    [​IMG] [​IMG] [​IMG] [​IMG]
    Quelle = OCXtreme
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    Quelle: XtremeSystems.org
    Kompatible Kühler:
    • Alpenfön Groß Clock'ner (nur mit leichtem Verbiegen der Lamellen!)
    • Arctic Freezer 7 Pro
    • Asus Silent Night 1+2
    • Asus Triton 79
    • Coolermaster Hyper 212
    • Noctua NH-U-12P
    • Scythe Mugen / Infinity
    • Thermalright IFX-14 (HR-10 passt nur mit Bearbeitung)
    • Thermalright Ultra 120 eXtreme / True Black
    • Thermaltake Sonic Tower
    • Xigmatek HDT-S1283 / Red Scorpion
    • Zalman CNPS 9500 AT
    • Zalman CNPS 9700 LED
    • ZHEROtherm Nirvana NV 120
    Wobei hier zu sagen ist, dass man von wenigen inkompatiblem Kühlern ausgeht, weil das Mainboard durch die flache Heatpipe sehr Kühler-freundlich ausgelegt ist
    __________
    Kompatibler RAM:
    • 2x 1GB A-DATA Vitesta Extreme DDR2-800
    • 2x 1GB Corsair XMS2 DHX DDR2-800
    • 2x 1GB Aeneon XTune DDR2-1066
    • 2x 1GB Patriot Viper DDR2-1150
    • 2x 1GB CompuStocx Diablo DDR2-1200
    • 2x 1GB OCZ Flex XLC DDR2-1200
    • 4x 1GB Crucial Ballistix (Tracer) DDR2-1066
    • 4x 1GB Corsair Dominator DDR2-1066
    • 2x 2GB Corsair DHX DDR2-800
    • 2x 2GB OCZ XTC Platinum DDR2-1000
    • 2x 2GB Apogee GT DDR2-1066
    • 2x 2GB Transcend aXeram DDR2-1066
    • 2x 2GB Corsair Dominator DDR2-1066
    • 2x 2GB G.Skill F2 4GBPK DDR2-1066
    • 2x 2GB G.Skill F2 4GBPI DDR2-1066
    • 2x 2GB G.Skill F2-4GBPI DDR2-1100
    • 2x 2GB Mushkin XP2 DDR2-1100
    • 2x 2GB OCZ Flex II DDR2-1150
    • 2x 2GB Chaintech Apogee GT DDR2-1150
    • 4x 2GB Transcend JetRam DDR2-800
    • 4x 2GB Corsair Dominator DDR2-1066
    • 4x 2GB OCZ Platinum XTC DDR2-1066
    • 4x 2GB OCZ Reaper HPC Edition DDR2-1066
    __________
    Die GTL-Einstellung:
    Die GTL ist ein Teiler. Sie ergibt mit der VTT multipliziert einen Wert in mV. Bei den meisten Board benutzt man den Teiler um auf einen höheren/niedrigeren (eben für die CPU perfekte) Endvoltage zu kommen. Beim Maximus II Formula wird dieser Teiler jedoch gefixt und dafür vom Endwert in mV abgezogen. Das hat den Vorteil, dass sich der Endwert bei gleicheingestellter GTL nicht durch die variable VTT ändert.
    Beispiel mit Asus P5Q Deluxe und vielen anderen Boards:
    VTT x GTL = mV
    1,1V x 0,63V = 693mV
    Beispiel mit Asus Maximus II Formula:
    VTT x fixed GTL = mV - mV
    1,1V x 0,677 = 744,7mV - 50mV
    Beide Beispiele kommen auf etwa das gleiche raus ;)
    Dickgedruckt = Jeweils im BIOS einstellbare Werte
    __________
    Northbridge Temperaturproblem beheben:
    Um die zu hohen Temperaturen der Northbridge zu senken, muss der Anpressdruck des Kühlsystems verstärkt werden. Dazu muss das Board ausgebaut und umgedreht werden. Daraufhin werden unter die Schrauben, die die Heatpipekühlung auf der Northbridge halten einfach zwei Unterlegscheiben (0,5 - 1mm) gelegt. Das erhöht den Anpressdruck und senkt gleichzeitig die Temperaturen der Northbridge.
    __________
    Messpunkte:
    Quelle: Awardfabrik.de (@arne)
    __________
    #1 devic, Aug 29, 2008
    3 people like this.
  2. devic
    Hab mir überlegt jetzt auch hier den Sammelthread zu eröffnen. Läuft noch @ Forumdeluxx, PCGH, Computerbase und Awardfabrik.
    Die Links werden noch angepasst ;)
  3. BoroBanana
    BoroBanana Grünschnabel
    hallo hab mir n rechner zusammengestellt und hätte gerne ein paar tipps bezüglich der bios konfiguration.
    hier erst mal die hardware details:
    -cpu intel core 2 q 9550
    -ram ddr 2 4gb GEIL
    -kühler coolermaster sphere
    -mainboard maximus 2 formula
    -hdd maxtor 500 gb
    -vga pci asus 9800 gt 512mb
    -netzt. 550 w be-quiet stp
    bios version:
    american megatrends
    0802
    07/10/2008
    welche daten wären für die konfi optimal.da ich nicht wahllos am bios rumhantieren würde ich mich über ein paar ratschläge freuen.
    gruß
    #3 BoroBanana, Oct 20, 2008
  4. tor123
    tor123 Wandelnde HDD
    Was genau willst Du denn wissen?
    (Hättest wohl besser einen eigenen Thread aufgemacht, das hier ist doch eher ein review).
    Wenn Du die Konfig im Standardtakt laufen lassen willst, brauchst Du im Bios gar nichts umzustellen (außer der Bootsequenz bei der Installation:)).
    Falls Du übertakten möchtest, schau Dich mal hier um: http://forum.sysprofile.de/overclocking/2259-overclocking-linksammlung.html ;)
  5. gotcha43
    gotcha43 Computer-Experte
    nice review, möchte mir eigentlich ein p5q-e holen, aber das teil toppt iwie alles, kostet aber 60 ökken mehr! das p5q-e reicht ja eigentlich, würde mir das mIIf nur wegen des geilen designs kaufen^^
    #5 gotcha43, Oct 20, 2008
  6. jokerx3
    jokerx3 Aufsteiger
    Tim
    Hey. . ich finde das Board ziemlich Geil und naja Momentan habe ich P5Q Pro.
    Ich bin drauf und dran mir das MIIF zu kaufen aber eine frage. . ist das da auf der Northbridge ein Fan ???
    Und wenn ja ist der wenigstens leise und oder kann man den einfach abmachen? sprich ist der bedeuted für die Temps ?
    mfg jokerx3
    PS: schoene review
  7. Yanou
    Yanou BIOS-Schreiber
    Fabian F.
    Cooles Review hab das Board ja :D
    Der Fan ist optional der liegt in der Schachtel ich persöhnlich hab den ne drauf.
  8. jokerx3
    jokerx3 Aufsteiger
    Tim
    hey Gut wunderbar dann glaube ich ist das mein neachstesBoard :>
  9. devic
    Bis 500Mhz ein super Board. Hat dank der präzisen Tweaking-Optionen wirklich Spaß gemacht.
    Ab ~520Mhz war dann aber Sense. Da hat weder eine spannungerhöhung auf 1,45V noch langwieriges NB-GTL-Tweaking was dran geändert. Ist echt schade...
  10. alex
    alex killed in action
    40873
    Hmm das ist echt blöd... Sogar mein altes P5K-E läuft schon mit FSB 460 (ohne Spannungserhöhung!).
  11. Yanou
    Fabian F.
    Wie kann ich die CPU Voltage erhöhen?
    Verzweifel daran gerade :D
  12. bernd das brot
    Justin
    Einfach direkt reintippen den Wert den du haben willst ;)
    #12 bernd das brot, Dec 25, 2008
  13. devic
    Oder mit "+" und "-" in den kleinstmöglichen Schritten ändern ;)
    Habe gerade mal das Update reingeknallt. Der Thread wurde in diesem Forum lange nicht aktualisiert.
Asus Maximus II Formula (Intel P45) - Similar Threads - Asus Maximus Formula
ASUS ROG Maximus Z690 Formula ARGB?
ASUS ROG Maximus Z690 Formula ARGB?: Hallo Leute, Ich habe vor mir in ferner Zukunft (wenn sich die Preise wieder stabilisiert haben), einen PC zusammen zu bauen. dafür habe ich mir das oben beschriebene Mainboard ausgesucht. Die...
Mainboards Apr 7, 2022
Muss das Asus ROG Maximus XII Formula-Mainboard Wassergekühlt werden?
Muss das Asus ROG Maximus XII Formula-Mainboard Wassergekühlt werden?: Hallo, ich habe einen Frage. Ich habe mir ein Mainboard ausgesucht und zwar das Asus ROG Maximus XII Formula, da habe ich gesehen das da oben links so [ATTACH] 1.Frage: Ich hoffe man kann es...
Mainboards Nov 27, 2020
UEFI Einstellungen Asus Maximus V Formula Z77
UEFI Einstellungen Asus Maximus V Formula Z77: Hallo, nachdem ich mein Windows 10 Pro 64 Bit neu und Clean installieren musste wollte ich es gleich im UEFI Modus machen. Soweit kein Problem, nur weiß ich nicht, ob ich alle "Bios" UEFI...
Mainboards Jun 1, 2016
I7 2600k mit Asus Maximus V Formula
I7 2600k mit Asus Maximus V Formula: Hallo, ich habe am vergangenen Wochenende meinen alten Q9550 Sockel 775 gegen ein I7 2600k 1155 ausgetauscht. Wurde auch mal Zeit, lach. Bei dem Q9550 fand ich es relativ einfach diesen zu...
Prozessoren Apr 15, 2016
Asus Maximus II Formula mit Intel Q9550 775 OC Tips und fragen
Asus Maximus II Formula mit Intel Q9550 775 OC Tips und fragen: Nabend, habe folgende Fragen zu dem schon in die Jahre gekommenen System. Ich habe die oben genannte Kombit mit 8GB DDR2 400 Standard Valiue Kingston Speicher. Die CPU hab ich auf 3.41 Ghz...
Prozessoren Dec 16, 2015
ASUS MAximus Formula 2 verliert Einstellungen!
ASUS MAximus Formula 2 verliert Einstellungen!: Mein ASUS Maximus 2 verliert jedes Mal die Bootreihenfolge der Platten. selbst das Wechseln der CR2032-Batterie hat nix gebracht. Woran kann das liegen? Sollte ich vielleicht ein neues BIOS...
freie Fragen Oct 24, 2011
Treiber ASUS MAXIMUS FORMULA SE
Treiber ASUS MAXIMUS FORMULA SE: Habe probleme mit den Treiber des ASUS Maximus Formula se. Die Treiber CD funktionieren mit Win7 nicht. Wo bekomme ich die Win7 Treiber her??? besonderst die von der SupremFX II mfg Fireb0ng
Mainboards May 5, 2011
Asus Maximus II Formula startet nicht
Asus Maximus II Formula startet nicht: Guten abend Ich habe da mal eine frage. Hab mir ein neues Mainboard zugelegt über ebay sollte aber nach reperatur von Asus wieder wie neu sein oder ausgetauscht.....!! Hab es den gleich mal...
Probleme mit Hardware Apr 30, 2011
Asus Maximus Formula + Windows 7
Asus Maximus Formula + Windows 7: Moin, moin ich habe da ein Problem mit der Installation von Windows 7 x64 auf einem Asus Maximus Formula mit 8GB Ram (4x 2GB), soweit läuft die Installation normal durch. Bis es zu dem Punkt...
Mainboards Jan 30, 2011
MSI P35 Neo2 vs Asus Maximus Formula 2
MSI P35 Neo2 vs Asus Maximus Formula 2: Hey Leute, hab jetzt hier nen MSI P35 Neo2 am Laufen. Ich habe aber auch noch ein Asus Maximus Formula 2 hier rumliegen und kann mich nicht entscheiden, welches ich behalten soll. Ist der...
Mainboards Jan 10, 2010
Corsair 8GB PC2-8500 auf ASUS-Board (hier Maximus Formula)
Corsair 8GB PC2-8500 auf ASUS-Board (hier Maximus Formula): Ich grübele derzeit aufgrund meines neuen x64 Betriebssystems darüber nach meinen Arbeitsspeicher zu verdoppeln. Hat jemand Erfahrungen mit dem Speicher von Corsair im doppelten Dual-Channel?...
Arbeitsspeicher Sep 25, 2009
Bios Update für Asus Maximus 2 Formula notwendig??
Bios Update für Asus Maximus 2 Formula notwendig??: Meine CPU (Q6600) wird auf meinem Asus Maximus 2 Formula nicht erkannt! Auf dem LCD Poster wird die ganze Zeit nur Welcome angezeigt und der PC startet, geht aus, startet, geht aus, usw. Dabei...
Mainboards Aug 8, 2009
Passt der Mugen2 auf das Asus Maximus II Formula???
Passt der Mugen2 auf das Asus Maximus II Formula???: Habe mich jetzt nach langen Überlegen entschieden das Asus Maximus II Formula zu kaufen! Wollte nur wissen ob da mein Mugen2 drauf passt oder ist der zu groß???
Mainboards Jul 25, 2009
Asus Maximus II Formula (Intel P45) solved
